Unable to use face of extrusion as a sketch plane
matthew_huck
Member Posts: 3 ✭✭
I'm trying to design a case to hold a PCB, and I'm now trying to add some snap clips (well the negative part) to the sides of the case. I've done one side, and no matter what I try, I can't select the other face of the inside of the case and use it as a plane for a sketch. All I can do is select, I would have expected to be able to add lines etc, but I can't. The other thing I notice that as soon as I select the face, the sketch in the Features list becomes italics?
I've tried toggling the planes on and off (using 'p')
Any ideas!
https://youtu.be/pGwg3dnrDxU
Any ideas!
@matthew_huck
Glad it's working again, weirdness is afoot.
I took a copy of your link and it also worked fine. You're probably way ahead of me but I dunno if you want symmetrical clips or anti-numpty asymmetric ones. If symmetrical than I'd be tempted to use the mirror feature rather than new sketch...
https://cad.onshape.com/documents/35b26b715c548ec1cc249f11/w/d49deee59ded112598ea36da/e/77a3810ad27515c9942a99b6
Cheers, Owen S.
HWM-Water Ltd5
Please will you share a link to the doc? Much easier to help that way.
Cheers,
Owen S.
HWM-Water Ltd0 -
https://cad.onshape.com/documents/f009d6c7574618a75a58f4d0/w/8336ef7a90d12733f3070e9b/e/c959b4ee1e33cc36929a3c2c
I'm trying to create a sketch on the inside wall of the opposite face to the one that has the 2 indents already
Hm, I branched a version, had a play on the main, and then restored to just after the branch, and now it works! Who knows! I'm not doing anything different to what I was.
@matthew_huck
Cheers, Owen S.
HWM-Water Ltd5
