add fasten mates
donald_8
Member Posts: 40 ✭✭
how do i add fasten mates to a part every 16 inches on center for framing a wall
Hi Donald. Your best bet is probably to add a Mate Connector in the part studio, and then 'Linear Pattern' that connector using 'Feature Pattern' option (still in the part studio). Then when you add your beam to the assembly, it will have all the required connectors.
https://cad.onshape.com/documents/7da2b702b57db09ea1cdad69/w/b0603891b8690ef3388b182e/e/476e4517ba5195ca269b394c
Jake Rosenfeld - Modeling Team5 -
thank you
1 -
If using the same part in each location then the assembly pattern feature is pretty neat, no need for additional mate connectors.
HWM-Water Ltd5
thank you
1 -
HWM-Water Ltd5
