parts appearance in drawing
hey,
i was wondering how can i edit the appearance of different parts in drawing (changing the material is not helping).
thanks a lot
thanks a lot
philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
@yuval_taff - It is not currently possible to control the hatch pattern in a drawing. We will be adding this capability.Philip Thomas - Onshape6
When you say a "Drawing" Do you mean a Part Studio or an Onshape Drawing?
If you just mean a Part Studio, you can right click on the part who's appearance you want to change and click "Edit appearance for part X..."
https://cad.onshape.com/help/Content/appearance_editor.htm
Changing the material of the part is useful for mass properties and similar measurements, but does not change the appearance of the part:
https://cad.onshape.com/help/Content/material_library.htm
https://cad.onshape.com/help/Content/massprops-ps.htm
when i say "Drawing" i mean onshape drawing.
is there a way to change the parts apperance there? (the lines that appear on each part)
Are you trying to change the line weight/thickness of a drawing view?
Or are you referring to changing the hatch lines of a drawing view?
