Extrude at an angle
daniel_chow
Member Posts: 108 ✭✭✭
Hey guys,
Just wondering if anyone know how to extrude at a 90 degree angle from one sketch to a second sketch that are 90 degrees of each other.
Here is my public doc:
https://cad.onshape.com/documents/eb2b5e1f3972ee91b47908de/w/27e670cb0e4a4c7cafa23b2b/e/9596de02a9aa2cf47b8db808
Thanks!
Thanks!
Thanks guys! Yes I tried various features in Extrude and Loft but not able to do this. I know I can set another plane and simply sketch the triangular shape I want and extrude it. But you know, bring Onshape I just thought there might be a quick workaround.
Jake, I did also try the rib tool, but I'll take your suggestion and try it again. How did you make Sketch 3 on an incline / angle like that without creating an angled plane?
Onshape rocks!!!1 -
@daniel_chow
I actually got it to work with a loft too, you just have to provide a couple guide vertices:
https://cad.onshape.com/documents/cbc0163e8e996c9d3986b089/w/ffad520e65fe3710ae29d43f/e/e6d7d60602fb2d3533ebbc9e
Jake Rosenfeld - Modeling Team6
hi, try Loft between these sections
1 -
Loft won't work because the bottom of the vertical sketch is on the same plane as the horizontal sketch.
If you're just looking to do a gusset you can do it this way. But I'm not really sure what shape you're trying to achieve.
https://cad.onshape.com/documents/2bd12d4f1859b7123e2a6718/v/73fd21de3eddfd6cb1f6c3ba/e/96c773d5da6e2010d2db205f0 -
this is rather unexpected behaviorTony_C_ said:Loft won't work because the bottom of the vertical sketch is on the same plane as the horizontal sketch.
not really, the loft doesn't like overlapping planer vertices. You're essentially telling it to connect 4 points to only two.konstantin_shiriazdanov said:
Loft works fine if you bring the vertical sketch off the bottom face.
have you tried the "Rib" feature?
https://cad.onshape.com/help/Content/rib.htm
https://cad.onshape.com/documents/cbc0163e8e996c9d3986b089/w/ffad520e65fe3710ae29d43f/e/11c486afca0b0db0e9a620fc
Jake Rosenfeld - Modeling Team0 -
Onshape rocks!!!1 -
@daniel_chow
Jake Rosenfeld - Modeling Team6 -
Thank you Jake I got it! See I knew there was an efficient way of doing this in Onshape!
Onshape ROCKS!1
