Screw threads: Pitch vs Form
tj_thorniley
Member Posts: 65 ✭
In the official tutorial on helical screw threads, an equilateral triangle is used for the thread form. It says something to the effect of, "Make the length of the triangle slightly less than the pitch of the thread."
How much less, exactly?
Threaded camera lenses and accessories, over the years, have generally come with one of three pitches: 0.5mm, 0.75mm, or 1.0mm. What size triangles should be used with these three?
Please check out this thread:-
https://forum.onshape.com/discussion/7620/how-do-i-add-threads-to-a-hole
Ilya provides a link to an excellent thread creator featurescript that will make your life much easier if you really need accurate threads on your models.
Cheers,
Owen S.
HWM-Water Ltd0
