<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
What is the fastest way to place multiple identical circles in a sketch?
michael_mcdonald047
Member Posts: 23 ✭✭
I was hoping to be able to select a dimensioned circle entity and paste a copy it at several locations. The transform function seems to move entities but not copy. Creating circle after circle after circle and then setting the dimension to all of them at once would work too but I don't see how to do that either. The pattern function will not help since the locations do not follow any pattern.
you may select all the circles and set equal constraint, or place points instead and use point pattern featurescript, but it works only on the feature level
6
6 -
Or you can copy and paste entitiesBusiness Systems and Configuration Controller
HWM-Water Ltd0 -
konstantin_
How do you set equal constraint as you mentioned?0 -
owen_
I tried that, but for some reason the copies wouldn't snap to anything. They were ignoring preselections and taking positions in undisclosed space.0 -
konstantin_
I found the equal constraint. Thanks for the help.1 -
@michael_mcdonald047 :
If you copy-paste, the copied circle should appear with transformation handles. If you click and drag on the square, the center of the circle will snap to implied snap points in the sketch.
https://www.youtube.com/watch?v=BR0dAJIjMZc
The equals constraint looks like an equals sign and should be in your sketch toolbar:
https://cad.onshape.com/help/Content/sketch-tools-equal.htmJake Rosenfeld - Modeling Team1
