Resizing Imports
Can you resize and edit imported stl files, and if so how?
I didn't think you could, but it looks like you can.
1) Import the STL as a mesh using the Derived feature.
2) Use the Transform feature or the scale featurescript that someone wrote a while back to scale the mesh.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/e33896542d12ef6ca815c617
1 -
I don't think OS will let you edit a mesh like you would normal surface geometry, but at least you can translate/rotate/scale a mesh. You can also use the vertices as reference snap points for other geometry.0
