Creat a T-piece out of two arc's
Kai_himself
Kai_himself Member Posts: 45 ✭✭
Hello Forum,
i need your help again.
Im trying to make a t-piece out of two arc's. I created the arc's with 3-Pouint-Arc and feeding. Now i would like to cut out the overlap in the middel of the arc's. I try the boolean operator, but the right solution is missing. I got only wrong results.
On the first picture you see the double arc.
On the following pictures you see the results of the boolean operator.
How i cut the middle out of the arc's ?
Here ist the link to the projekt: https://cad.onshape.com/documents/9a8c0aecf6767e09f530f535/w/005aa049af7ccc68815152aa/e/5d4e771f31850bc0087467a9
Greetz Kai
