skRegularPolygon -> opExtrude
ivan_soldatov
Member Posts: 5 ✭
Hi,how use skRegularPolygon in opExtrude , and do it solid body?
view 75 code line
https://cad.onshape.com/documents/6791ae7d97616661b011c396/w/b379dc7982120ded569f6f4c/e/3af5b1444179fb65254322c7
view 75 code line
tipically if you need to use sketch region to make a solid you need to use qSketchRegion query. but it need the sketch to contain only one closed contour, or one contour with inner loops. if the sketch contains several contours you may use qContainsPoint(qCreatedBy(id + "sketch1", EntityType.FACE), vector(0,0,0)*meter) to filter some specific sketched face
5
5 -
konstantin_shiriazdanov said:@tipically if you need to use sketch region to make a solid you need to use qSketchRegion query.very sipmle).Thanks Konstantin .
