How to strip the units from a length?
jackson_kingjackson_king OS Professional Posts: 80 PRO
Hi All,
Is there a way to strip a length of it's units so the decimal number can be used in a "ceil(#/#)" equation?
I am trying to use configs to create an expanded metal/grating generation part studio and have it working well except for getting the desired sheet size to auto size.  I am using measure distance FS to get the lengths and widths for the distance of the pattern and am trying to use that measure distance number in the ceil function to drive the instance count. In this case, ceil(#Desired_Length/#Length) or ceil(#Desired_Width/#Width).
Here's the document:
https://cad.onshape.com/documents/07f282dcddf2935fa6750b71/w/2c0dd72f79a3f141eac8e0ae/e/de6fa0c8db0a64009288fb77
Thanks in advance!
Jackson
  • jackson_kingjackson_king OS Professional Posts: 80 PRO
    Thanks @Jake_Rosenfeld!  I was testing things before submitting the question and never had it as a #variable/#variable, just a number/#variable.  What you said makes perfect sense and it works!
    @Jake_Rosenfeld, is there a way to remove the units if I needed too?
    Jackson
    value with units has internal structure of map type, so #length.value should give a unitless number
    Thanks guys! It all works well now. I think my next attempt should be turning this thing into featurescript. Which should be interesting as featurescript and I don’t see eye to eye on things sometimes.
    Jackson
  • EvanReeseEvanReese Member, Mentor Posts: 2,869 PRO
    A better way of doing this is dividing by the unit.  If you want the number of inches in #length, use #length / in
    Getting the value like @konstantin_shiriazdanov proposed will always give you the length in whatever internal units we're using, which may not be what you want.
    How might I approach this in Featurescript if I don't control which units the user selects?
  • alnisalnis Member, Developers Posts: 453 EDU
    @Evan_Reese not sure if this is quite what you'd want, but for user inputs, could you have a length parameter and dropdown for units?
    @Evan_Reese
    It might be easier to answer if we had additional detail about what your user inputs are and what you are trying to do with them
    That's a good suggestion. That would get the job done, but my intuition is instant that there's a less kludgey way... or at least one where the user doesn't have to be aware of the kludgeyness. On the other hand, the fact that there doesn't seem to be an obvious answer probably indicates a deeper issue with my whole approach.
    As a learning exercise, I'm trying to plot points to a sine wave like this:
    y = amplitude*(e^(-decay/100*x))*cos(x*frequency*degree)+amplitude;
    Amplitude, frequency, and x are all valueWithUnits (lengths), and I think that's what I want, but cos() wants an angle, not the unit mashup I have. Should I change all of them to just values? if so, how do I get the right units without the user having to think about it?
    @Evan_Reese
    Issues with units usually indicate an issue with the equation itself; if you were solving this equation on paper for a given x value, you would expect all the units to cancel appropriately to give you the right answer.  So to tackle it in parts:
    (e^(-decay/100*x)): this is a scale factor, and should be unitless.  Since `x` is a distance, I would expect `decay` to be in distance units, describing how far along the x-axis you want this scale factor to be (e^(-1/100))
    cos(x*frequency*degree): As this is right now, I would expect "frequency" to be in inverse distance units (i.e. "1 / distance"), and that (frequency * degree) forms a statement of "for every (1 / frequency), the cos wave changes by one degree".  I do not think this is the intention, it seems that you are having the user supply "frequency" meaning "how frequently does the cos wave pass through a full cycle".  In which case the correct equation would be: cos(x*(360*degree/frequency)); and you will see here that that the units just fall out correctly, without having to strip anything of its units.
    @Evan_Reese
    At least I was right about being wrong :D. my algebra has never been the best. Thanks for the rundown, I'll self-educate more.
  • ilia_mazlovilia_mazlov Member Posts: 5
    Hey! Not sure if I'm doing something wrong here or it's just a bug, but variable doesn't work in helix "target revolutions": niether it works with #BaseHeight / 1.5mm nor with #BaseHeight / 1.5, nor with just a single #BaseHeight.
  • _anton_anton Member, Onshape Employees Posts: 530 image
    This expression is equivalent to (#BaseHeight / 1.5) mm because, if it worked differently, you'd be unable to write, say, 1/2mm.
    Simplest fix is something like #BaseHeight / (1.5mm).
  • jelte_steur_infojelte_steur_info Member Posts: 655 PRO
    @Evan_Reese
    Like @Jake_Rosenfeld said; "Issues with units usually indicate an issue with the equation itself".
    This is very true so probably you'd want to avoid having to use this. But just to satisfy my curiosity i had to think it through.
    Because in isLength parameters, users are free to input e.g. this:
    "(100 millimeter * 1 inch )/ (0.1 meter)".
    So what would the unit be?
    If you'd ever want to use such a function, I think an isReal parameter with a Unit Enum would be the only way to go.
    Users are then still free to use expression to come to the number value. (but it has to be unitless)
     Inside the feature, a multiplication of the unit with the parameter would create the valueWithUnits.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    @jelte_steur814
    The result of your expression is a length, which can be shown in any length units.  Onshape will use the length units specified in your workspace to show the value.  I think the thing that people seem to find a little hard to digest is that "1 in" and ".0254 m" evaluate to the exact same length value -- it doesn't matter what units were specified in the expression; what matters is the represented length.
    @ilya_baran. Agree. And my point is that you cannot derive from inputs what Unit the user was thinking/intending/inputting because it can be a mix as long as it evaluates to a lenght.
    @_anton thank you for giving this advice, now I see that the "units operator" is applied after meth operators. Thank you very much!
    I haven't noticed low "units operator" precedence. Thank you very much, the parentheses works like charm!
