Using custom functions as input parameters of part studio features
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
Currently when I import a function inside FS tab and apply a feature in part studio the function definition stays invisible for PS invironment and I can't use it in input fields of features and dimensions. So maybe there exists a way to import function definitions globally?
If you want to use a function that is defined in a feature studio within part studio expressions, I recommend making a feature that sets a variable to the custom function and then using that variable. Here's an example document: https://cad.onshape.com/documents/501d4d371d06dc0269408354Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1
Thanks, should have thought about variables first.
