How to Pattern a Reconfigurable Pattern?
TrexationTrexation Member Posts: 1
I am making a tent shaped structure with a variety of vertical supports placed around a bottom circular support.
I would like to select all of the parts from a configured circular pattern (with a varying number of parts) to be used in a separate linear pattern does anyone have a suggestion as to how to go about this?
Thanks,
Trex
    use "Feature pattern option" in the linear pattern, but creating part patterns in part studio is not a good practise
  • scott_willis165scott_willis165 Member Posts: 20 ✭✭
    Why is creating part patterns in part studio not a good practice?
    @scott_willis165 I should have said - it's not a good practice to create multiple copies of part and not to delete them later, it will cause problems in identifying original part when inserting in assembly or drawing and making a BOM
