Sheet metal flat pattern nesting
kevin_ward365
kevin_ward365 Member Posts: 2
I am creating some simple sheet metal designs that I need to nest the flat pattern into a drawing for laser cutting.  I was trying to take the flat pattern and make a new part studio but for some reason I can't figure it out.  Is there something I need to do?  I can export to DWG but then I can't really do anything with it.  Thanks in advance for helping this noob.
  • Jake_Rosenfeld
    @kevin_ward365
    You can insert your flat patterns in an Assembly and lay them out there (possibly by also bringing in a layout sketch).
    If you really want the flats in a Part Studio, you can first bring them into an assembly, then create a new Part Studio in-context of that assembly and use the Transform feature with copy-in-place to make the flats movable.  I gave a more detailed description of this in-context trick here:
    https://forum.onshape.com/discussion/comment/37447#Comment_37447
