Where is the center line tool in the sketch tool bar?
paul_headley
Member Posts: 1 ✭
Sorry for the newbee question, used SolidWorks for many years. The help section shows the tool, my sketch screen doesn't
1
@paul_headley
If you want to sketch a centerline with keyboard short cuts, use 'l' then 'q'.
'q' is the shortcut for construction, and 'l' is the shortcut for line.1 -
It's called Construction and looks like vertical solid and dashed lines with two arrows in between.1
