is there a way to copy drawings on google classroom onto onshape?
  • Jake_Rosenfeld
    Jake_Rosenfeld Posts: 1,646 image
    edited March 2018
    Hi @kolby_finch
    If you download the pdf you can reupload it as a tab in the Onshape document, but it will stay as a viewable PDF rather than being an editable drawing.  If you want to upload it as an editable drawing, you would need to get the DXF or DWG file of the drawing.
    Edit: this help documentation shows how to import files into Onshape https://cad.onshape.com/help/Content/uploadfiles.htm
