Different values for the variables following the configuration
ludovic_lebreton467
Member Posts: 2 ✭
Hello,
I want to be able to assign to a variable different values for the default, minimum and maximum values depending on the different configuration choices. Is it possible and how ?
Sorry, all the configuration inputs are independent. The best I can suggest today would be making a custom feature that checks whether the combination of all the configuration tables and inputs is valid and fails the Part Studio if not -- that way you'll at least know you won't insert an invalid configuration into an assembly or drawing.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
