Why can't I edit my Sheet Metal Model?
lars_rengersen
Member Posts: 32 PRO
I am designing a box and I am using the sheet metal function.
Project / file can be found here.
Now I want to increase the sheet metal thickness.
However, when I edit the sheet metal model the green tick to confirm my changes is inactive/not clickable. See attached screenshot.
In another sheet metal model it did work as I expected and could edit normally.
Does anyone have a clue why the change is being locked?
Thanks in advance for your help.
I see no reason for it. Could you please SHIFT-reload your browser ( this clears local cache) and try again?5
Thanks!It was a browser issue indeed. I opened my document in Firefox instead of Safari (my default browser) and I was able to update the values normally.0
