FIxed components on an assembly still move
Hi,
if I make an assembly (all parts fixed) and insert it into another, I still can move the components of the first assembly (that has became a sub-assembly) one relate to other, is it right? Normally in other CAD system when you insert a sub assembly, you can't move sub-components of the sub-assembly, where am I wrong?
https://cad.onshape.com/documents/efec766dc1d1f5db65f77985/w/bb75b6ba1dc855d9ceff346d/e/8947c9c603a9decc1639ed75
  • michele_cavallerin
    michele_cavallerin Member Posts: 5 ✭
    edited May 2018
    Hi,
    still have an issue about this; if I insert an assembly inside one other, why can't I fix the first one as I know this is a static frame?
    https://cad.onshape.com/documents/fb70795fce37460b74ff9f30/w/b59d16992f10c1f480f2ff2d/e/c55a29af0020d4b5ac5ab72a
    Just found the solution, only needed to fix one part inside the subassembly.
    In any case still I don't get the reason of this, but maybe it's just because this is different from other CADs.
    Regards.
