Whats the easiest way to set a part in scale 2:1 to its original for a 3D print?
arne_stange
Member Posts: 1 EDU
Hi,
Simple question: I want to print a part but before exporting it I want to scale it twice as big as the original in the partstudio. So that 1mm in the part studio corresponds to 2mm of the printet part.
thanks for your help,
Arne
Arne
Or... export the STL as is and use your slicing software for the scaling.7
HiHopefully you'll be pleased that there's a simple answer
The transform function has a scale option.Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd3 -
