Copy
Can anyone advise please. I am trying to copy a part in an assembly. the part needs to be copied 236.5mm above the original. Is there away to copy and paste in exactly the correct position. any help would be appreciated thank you .
Regards Brian
Regards Brian
@brian_pinder662
Maybe what you're looking for is Assembly Linear Pattern?
https://cad.onshape.com/help/Content/assemblylinearpattern.htm
Jake Rosenfeld - Modeling Team6 -
Copy, then paste the part in the assembly. Then apply a fasten mate and use the offset options to offset by 236.5mm. If the parts are fixed as such then leaving the fasten mate is fine OR you can delete the mate but the positioning will stay and you can choose to fix, group, or do whatever you want moving forward.5
Not tried it yet but feel sure either of your replies is will do the trick.
Once again many thanks Brian.1
@brian_pinder662
