OMG !!! Look what happened
paul_bartlett
Posts: 98 ✭✭
I created this assembly with all the colors the way I wanted them, then did a "Create Parts Studio in context" so I could Cut my outside profile to finish it. All my color assignments changed. Anyone have a solution to this or a workaround. I feel like my last few days work have ben for nothing at this point. I might add that it brought OnShape to its knees when I did this,but it did do it.
This is the parts studio after the in context process was done
https://cad.onshape.com/documents/47f8ecb372dd67b4c4fb5112/w/ba34d8bff1f38e186692569e/e/bb40b8d403f52a9e9c3059c3
since you created all the rings in different part studios you now can try to insert a sketch for prodile cut in assembly and edit each ring in context of it part studio using that sketch. it would allow to keep part appearence because you will edit part itself. with you approach to copy bodeis in place it doesn't keeps appearence because new body is created0
It has taken an hour or so but I have been changing the appearance of the parts selecting many at one time. Goes faster than I thought it would. Faster I suspect than in context each ring etc.
