Onshape & Laser Measuring Devices (LMD)
robert_melascaglia
Member Posts: 45 EDU
in General
Hello
In lieu of 100% measurements from taping (let's say); can I import data from a LMD to fix important points spatially to begin a sketch? Can an excel file of spatial coordinates be utilized bu Onshape?
Thanks for your assistance.
Robert
owen_sparks
Member, Developers Posts: 2,660 PRO
I understand you can import a csv file containing point data and work from that. I'm sure someone with the experience will be along shortly...Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5 -
mthiesmeyer
Onshape Employees Posts: 115
@robert_melascaglia
You can see an example featurescript for importing a csv file and turning the data into point bodies/curves here. Alternatively, if you are looking for a slightly more complicated example, this featurescript takes a csv and builds an airfoil with it
Best,
Mike5
HWM-Water Ltd
Best,
Mike
