How can I create a funnel between two parts?
chris_cartwright
Member Posts: 3 ✭
Link to document:
I want to merge the parts Top and Part 3 via the two surfaces created. I've looked around and most posts say create a surface then use Thicken, but I have an irregular shape. The top of the funnel is wider than the bottom of the funnel. I also tried the Fill tool, but it just gave me the message 'Sections do not enclose a region'.
Thanks
Personally I'd loft a solid then shell it, or if the top and base are concentric then a revolve would be easier.Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5
HWM-Water Ltd5 -
I used the revolved as shown by larry_hawes
http://www.youtube.com/watch?v=opPz9UiTEHM
