How to set up units for a sheet metal part in the table view when you want to export some parts?
rraffaell73rraffaell73 Member Posts: 13
The case is: that when I want to export some part from sheet metal flat view, the units aren't the same of my drawings...
  • schaeffer_reesschaeffer_rees Member Posts: 4
    Are you accounting for stretch out? The flat view and the part you designed shouldn't be the same. Are you familiar with the concept of bend deductions and stretch out? If this isn't the issue please disregard.
