Transforming Orientation of Complicated, Imported Assembly?
I just imported an assembly of my 3D printer. It was just something I grabbed from online, and it is "simplified" in that it doesn't have things like nuts, belts, PCBs, cables, etc. I also just grouped all the part together rather than going through and recreating every single mate type, and this will be plenty accurate enough for me, since I am just designing something that attaches to the printer's 2020 extrusions.
However, during import, the front & back ended up swapped. Is there a way to swap the front & back orientation of this grouped assembly (180 degree rotation of the grouping around the Z axis)?
Thank you
