Trouble adding flange to sheet metal model
dane_rasmussen
Member Posts: 6 ✭
I have two sheet metal parts with similarly sized and shaped holes that need a flange added to one side. On one of the parts the flange worked fine, on the other part I cannot get the flange tool to work. It only gives an error: "Flange did not regenerate properly: error regenerating." Given that the feature the flange is based on has almost identical geometry to the other part that worked, I don't understand why it will not regenerate.
Here is the document in question: https://cad.onshape.com/documents/4712951cf0f10518e4495233/w/49f4e0d6a681eb2828d656fc/e/d077ec5ffe64ffde84e284dd?renderMode=0&uiState=660cc6ce372ecb776cfa4005
Done now1
@dane_rasmussen
Please share the document with support and ping me - I can fix it for you. Share-> Share with Onshape support
Thanks! Just toggled sharing on.lana said:@dane_rasmussen
@lana were you able to access the document or is there some other permission I need to change?0
Please try sharing again - I did not check soon enough and it got unshared.
Should be good to go, I didn't realize that the sharing had an expiration. Thanks!0
Done now1
