lofting help
don_howe
Member Posts: 115 ✭✭✭
I'm having trouble getting OS to recognize the middle profile of my loft and it doesn't like guide curves. The two end profiles are splines and the middle profile consist of two curves tangent to each other. Any help appreciated.
https://cad.onshape.com/documents/c1588d22f61042528f34b0d7/w/0f0040e8aaa64f828f328c98/e/d7a7a741c7e5427185535807
Optionsshanshan Member Posts: 147 ✭✭✭don_howe, 1).I noticed that there is no intersection points between the curve in the sketch 4 and the the curve in the sketch 1(or sketch 9),that is why you can not choose sketch 4 as guide lines.
2).about the middle profile,it is consist of two tangent curves, you can choose them together from the feature list.5
But I see something strange Sketch 9 and Sketch 1 are the same, why dont you use only one?
Any way, I made a couple of hulls that may help you. I changed one of the Sketches that was circles for a spline line.
Here:
https://cad.onshape.com/documents/4063e8b89cd143289305e07a/w/0eb7fb89c24040c99c84115a
Any way in order to work well there is too manny Sketches try to reduce it to a vertical one, an horizontal and the ribs, you should not need more, and will be easyer to work.
gonzola_chomon, I got rid of the extra sketches. Thanks for pointing that out to me.
