Mirror in a circular way?
rami_al_zoubi
Member Posts: 6 ✭
Hi as you can see Im trying do make a D-Pad like seen here ( the 4 arrow buttons facing to the middle):
I already finished one of the buttons by drawing the path of the button and then sweeping around the path. Is there an easy way tu duplicate them so i get the same layout with the the 4 buttons facing each other.
Hello Rami. Circular Pattern would be the tool to use. Take a look at the linked document below. Pattern tools can be used for Parts, Features and Faces. - Scotty
https://cad.onshape.com/documents/0843eefeb768b78d8d7d6e68/w/8bea2363b44ba38f6e0d97fa/e/fdfeef0857fc3d0ede40fc66
