Mirror Part as New Part
I imported an IGS file and tried to mirror it and deleting the original is there a work around for that? Also is it possible to mirror as new part so that any changes are also transferred to the mirrored Part?
  • shanshanshanshan Member Posts: 147 ✭✭✭
    wayne_love,if you get a new part by "mirror",I want to remind you that they are not relative to each other in Onshape,after "mirror",if you want to add some other features to the first part, the second part will not be updated.So you can rollback to mirror,and add some features you want, then roll to end,both of these parts will be undated together.
