Etching a curve onto a non-cylindrical curved surface
marcin_fortuna
Member Posts: 4 ✭
Hi there, I'm quite new to Onshape, and I've been trying to etch this helical pattern onto the face of this loft, but I can't seem to find a way how to do it. Does anyone know how to do so? Thanks in advance.
You can create a helix, then use it as the sweep path for a horizontal line which gives you a "cutting" surface body. Intersect this surface body with the other body, giving you the curve. e.g. https://cad.onshape.com/documents/3bee98d9ae5ba60a27ee4ede/w/196d09adaf5c961102cfd33c/e/1c87edde23dd6258e11b3091
1 -
Is there any way to make the size of the rotations complimentary to the shape of the loft as it changes? Because some stick out much further than I'd like them to.GregBrown said:You can create a helix, then use it as the sweep path for a horizontal line which gives you a "cutting" surface body. Intersect this surface body with the other body, giving you the curve. e.g. https://cad.onshape.com/documents/3bee98d9ae5ba60a27ee4ede/w/196d09adaf5c961102cfd33c/e/1c87edde23dd6258e11b3091
