How can i place the leader inline with the text.
Mark_Frost334
Mark_Frost334 Member Posts: 2 PRO
i cant find any option to move the leader alignment from under the note to the centre of the note.
  • glen_dewsbury
    glen_dewsbury Member Posts: 1,376 PRO
    @jack_stevens334
     I haven't looked at that before since I mostly use ANSI standard which puts the leader in the note center. When I switch to ISO standard the leader is under the note. Once started in either standard I was unable to change. Hadn't been a concern to me either way.
  • glen_dewsbury
    @jack_stevens334
  • Mark_Frost334
    Thats solved the problem. Thanks.
