FeatureScript editing logic function
graham_lock
Member Posts: 276 PRO
Hi,
I've found the documentation for the Editing Logic function but I can't see how to actually link it to the feature?
Any example appreciated.
RENDERCAD
________________________________________________________________________0
RENDERCAD
________________________________________________________________________0 -
Thank you but I get an error message of document doesn't exist or I don't have permissions?0
There you go, it's set to public now.Also here is more explaining how edit logic works: edit logic forum post
RENDERCAD
I've listed this from frame.fs (forgive the formatting, I dont write the forum software we use):/*** Create frames from a profile and set of path selections.*/annotation {"Feature Type Name" : "Frame","Manipulator Change Function" : "frameManipulators","Filter Selector" : "allparts","Editing Logic Function" : "frameEditLogicFunction"}export const frame = defineFeature(function(context is Context, id is Id, definition is map)
The annotation that precedes the function code specifies a bunch of useful bits. This is how we tell the function what manipulator function to use and what editing logic function to use.0 -
Fantastic thank you.
The link to edit logic forum post points to the sample document?0 -
RENDERCAD
Thank you!0
