FeatureScript editing logic function
graham_lock
graham_lock Member Posts: 277 PRO
Hi,
I've found the documentation for the Editing Logic function but I can't see how to actually link it to the feature?
Any example appreciated.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,960 PRO
    Here is an example of how to use it: Editing logic example
  • graham_lock
    Thank you but I get an error message of document doesn't exist or I don't have permissions?
  • MichaelPascoe
    edited July 2024
    There you go, it's set to public now.
    Also here is more explaining how edit logic works: edit logic forum post
  • jnewth_onshape
    jnewth_onshape Member, Onshape Employees Posts: 89 image
    edited July 2024
    I've listed this from frame.fs (forgive the formatting, I dont write the forum software we use):
    * Create frames from a profile and set of path selections.
    annotation {
    "Feature Type Name" : "Frame",
    "Manipulator Change Function" : "frameManipulators",
    "Filter Selector" : "allparts",
    "Editing Logic Function" : "frameEditLogicFunction"
    export const frame = defineFeature(function(context is Context, id is Id, definition is map)
    The annotation that precedes the function code specifies a bunch of useful bits. This is how we tell the function what manipulator function to use and what editing logic function to use.
  • graham_lock
    Fantastic thank you.
    The link to edit logic forum post points to the sample document?
  • MichaelPascoe
  • graham_lock
    Thank you!
