Question on making remove extrude in between two concentric circles
mokhtar_rashwan
Member Posts: 5 ✭
Hi
I have been designing a sample cell for my experiments. Part of the design should include two concentric circles, the inner one should be open and in between them I should remove partially to let an optical window sit into it.
I can't get it so far on onshape.
Any help with this would be highly appreciated!
Attached a screenshot of my design progress so far.
Thanks
Hi, there is no screenshot.0
Here is the screenshot.
Is this what you want?It's just two extrude cuts, one through, one to a blind depth (you do have to turn sketch visibility back on after the first cut). Good luck, hope this helps
Yes, That's what I want. Could you expand more on the order and details of the extrudes?
Thanks!0
