How to print a drawing at a 1:1 scale if the drawing is much larger than a regular sheet of paper?
I want to print out a scale drawing of this aircraft I have designed, but it is 1.9 meters in wingspan and obviously does not fit on a regular A4 sheet of paper. Is there a way to subdivide it into say a 4x5 grid of sheets to then print out, or at least something to that effect?
  • DavidvanderMeerDavidvanderMeer Member Posts: 15 ✭✭
    I had to do something like this recently, though not in Onshape, but the concept is the same.
    We needed a 1:1 paper template that would span across 5 separate sheets of A1 paper. I added markers to the model which would project onto the drawing, two markers on each overlapping side of the paper, so all the sheets could be aligned using those markers. I numbered the markers as well so they could easily be identified and matched. Then we printed the sheets, cut out the shape, sticky-taped them together, and we had our 1:1 paper template.
    Most PDF viewers can do this. Just "Print" or export your drawing to PDF, then print from a PDF viewer.
    Eg. Here's Adobe Acrobat Reader and PDF X-Change Editor:
