Onshape is not connected. Your document is saved. Refresh the browser to continue working
Why do i get this message???, also using AVG
It's usually a antivirus/ firewall blocking thing. It's probably AVG. Can you pause it/ swithch off to see if Onshape works again?
Engineering textbook: https://hwh.stephenteacher.com/txtbook.html0 -
On my laptop aswell on my desktop both using AVG. On my laptop there is no problem on my desktop OnShape won't start????
Shutting down or blocking AVG is not the solution. Just shutdown everything and still the same problem.
Same here, using AVG. I have tried turning off AVG, making an Exception in AVG etc etc. No joy. Running the Onshape check shows green ticks all the way down. I have made no changes to my PC but this just started happening randomly. Grrr!
Sometimes when your connection is not stable or you are inactive for some time you get this message.
