Onshape is not connected. Your document is saved. Refresh the browser to continue working
Why do i get this message???, also using AVG
  • Ste_Wilson
    Ste_Wilson Member Posts: 691 EDU
    It's usually a antivirus/ firewall blocking thing. It's probably AVG. Can you pause it/ swithch off to see if Onshape works again?
  • kees_hennen
    kees_hennen Member Posts: 4 ✭
    On my laptop aswell on my desktop both using AVG. On my laptop there is no problem on my desktop OnShape won't start????
    Shutting down or blocking AVG is not the solution. Just shutdown everything and still the same problem.
  • andrew_gunn961
    andrew_gunn961 Member Posts: 2 ✭
    Same here, using AVG. I have tried turning off AVG, making an Exception in AVG etc etc. No joy. Running the Onshape check shows green ticks all the way down. I have made no changes to my PC but this just started happening randomly. Grrr!
  • muhammad_tayyab_arif
    muhammad_tayyab_arif Member Posts: 13 ✭
    Sometimes when your connection is not stable or you are inactive for some time you get this message.
