Move / Rotate within sketch
imagineered
Member Posts: 57 ✭✭
Any way of moving, rotating 1 or more items in a sketch without having to redraw?
Hi @imagineered here a few post discussing this issue.
https://forum.onshape.com/discussion/568/how-can-i-translate-a-sketch
https://forum.onshape.com/discussion/1006/rotating-a-sketch-on-plane
https://forum.onshape.com/discussion/591/how-to-rotate-a-sketch-element
And an improvement request to add Copy/Move/Rotate sketches
https://forum.onshape.com/discussion/1466/add-precision-copy-move-rotate-to-sketches
In order to move or rotate a fully defined sketch:
1. Remove the constraint that locks the sketch to an entity (In the video below the origin)
2. Move freely in space dragging/snap it to a specific position in mi case the point I drew.
To Rotate remove the Horizontal constraint and add a dimension angle.
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions6 -
This feature (Skethc Transform) has now long since been added:
