How to rotate a sketch element ?
jean_didier
Member Posts: 28 ✭✭
I'm trying to rotate a square and i can not find a rotate tool, am I missing something ?
Thanks,
Thanks,
1
abefeldman
Member Posts: 166 ✭✭✭
@Jean-Didier - We don't yet have a dedicated rotation tool for sketching, but you can "Show Constraints" in the sketch dialog and remove the horizontal and vertical constraints in your rectangular feature to allow it to rotate. I'll add your request to the improvement.
Abe Feldman
UX/PD/Community Support5 -
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
Here's a workaround:
1. Draw rectangle
2. Tick show constraints and delete Horizontal or Vertical constraints that are automatically added to rectangles
3. Dimension the plane to rectangle, it should show angle dimension of 90 degree. If dimension is greyed out, check possible over constraining and RMB click dimension and change to driving
Images have extra line, you can just omit that.
//rami6
1. Draw rectangle
You can use the sketch transformation tool : https://cad.onshape.com/help/Content/transform-sketch.htm
