Sketch features not showing as fully defined
I'm using chrome as my browser and Windows 10.
If you haven't added an "external" constraint (coincident constraint to the origin, planes, or other geometry) then it will float around and be under constrained.Senior Director, Technical Services, EMEA0
Is there possibly a setting that could force all dimension to stay as blue, under-defined?
All my sketches are behaving this way now. They used to behave as expected for all new and past documents I edited. Now every dimension will be blue, every line and point will be grey no matter what. This is true for an new document I make.0 -
"every line is grey" sounds like you are not actively editing the sketch? Right-click "edit sketch".
Senior Director, Technical Services, EMEA0 -
Found out it some kind of glitch with the browser, had to restart it, working normal again now.
I've been using OnShape for a few years now. Suddently, anything I draw shows as "Sketch 1 is not fully defined." Even a simple circle or single line now has this error. What might be causing this?
Is the simple element constrained to or dimensioned to the origin? - Scotty
Having the same issue, when using a Point it always makes the Sketch "not fully defined", it does not seem to matter how or where.
Test: draw a square, add a point, get error.
Anything that is under defined is flagged, except construction line endpoints.
