Sketch one not fully defined on "Keyboard Kickstand" part
Just starting out in onshape with limited cad experience. Designing a small "kickstand" missing from my keyboard. Can anyone tell me what I need to do to correct this? Not sure how to direct you to the part, except it is in the public section under "Keyboard Kickstand"
  • jelte_steur_info
    jelte_steur_info Member Posts: 676 PRO
    look for the blue stuff; those are the undefined geometries.
    I found this in the corner where you also define the 90 degrees. (tip: perpendicular constraint is cleaner, unless you want to vary this angle)
    these line endings are not coïncident, or missing a tangent constraint perhaps…
  • charles_castle
    charles_castle Member Posts: 5 ✭
    Thanks so much — I changed the definition from 90 degrees to perpendicular. But I'm not sure how to fix the line endings — any suggestions would really be appreciated!
  • MDesign
    MDesign Member Posts: 1,464 PRO
    edited December 2024 Answer ✓
    assign and coincident constraint or just drag drop them on to each other that you want to be coincident. looks like they should probably be set to tangent as well
  • charles_castle
    Yea! It worked! Thanks so much for your assistance! It is appreciated!!! (Happy Holidays!)
