Create a gear teeth on an oval ring gear
rodrigo_coppelli
Member Posts: 6 EDU
I'm trying to put teeth into a oval ring gear. Similar to something like this picture. I can make the outside oval, but for some reason cannot make the teeth and pattern it around the oval. I also have a larger ring and many more teeth so making them individually would be a large task.
Here's my doc.
Any help appreciated. Thanks!
Curve pattern should work.
Thank you! Funny, I tried that, and it didn't work. Something must be wrong with my sketch. I will check it out.
