Appearance
Hello
Is there a keyboard command in Onshape to set the appearance of a part to transparency 50% and back?
Is there another quick way?
Thank you for your answer(s)
Hansjürg
  • S1monS1mon Member Posts: 4,220 PRO
    50%? No, but shift-T will make parts temporarily transparent. I would prefer that it wasn't quite so transparent. There's also "translucent" mode under the Camera and Render options menu (the isometric cube menu on the upper right). That makes all parts translucent, which can be useful while trying to work on internal features. By default, there's no keyboard command for that, but you can assign one.
  • hansjuerg_jenzerhansjuerg_jenzer Member Posts: 16
    Hi Simon
    Thanks for your reply.
    I have now tried it with a custom FeatureScript (with Youtube, ChatGPT and Preplexity).
    I have a code that only gives an error on the last line.
    Everything else seems to be OK.
    The error message:
    mismatched input '<EOF>' expecting {'[', 'box', '::', 'boolean', 'number', 'string', 'array', 'map', 'builtin', 'function', 'undefined', '{', BOOLEAN, NUMBER, ID, STRING}
    34:2 Feature Studio 1
    Can you help me with this?
    Many thanks Hansjürg
    Code:
    FeatureScript 2559;
    import(path : "onshape/std/common.fs", version : "2559.0");
    annotation {"Feature Type Name" : "Apearance 50", "Feature Type Description" : "" }
    export const myFeature = setPartTransparency function(context is Context, id is Id, definition is map)
    precondition
    annotation { "Name" : "Auswahl", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 5 }
    definition.selectedEntities is Query;
    setPartTransparency(context, definition.selectedEntities);
    setPartTransparency (context is Context, selectedEntities is Query)
    if (size(evaluateQuery(context, selectedEntities)) == 0)
    { throw regenError("Bitte wählen Sie mindestens ein Bauteil aus.");
    } setAppearance(context, {
    "entities" : selectedEntities,
    "appearance" : {
    "opacity" : 0.5
    FeatureScript is designed to modify a part studio in a controlled way. You can tie keyboard commands to built-in features and commands, but as of yet, you can't do so for custom features. You can use option/alt-c to search for a command and then type some characters to get to a custom feature, but that's not as quick.
    What are you trying to accomplish by setting/unsetting the transparency?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,753 PRO
    You could use a configuration checkbox to configure the appearance of the part(s). Or use something like the "part color" FS to make it easier to configure than using the configured properties route…
    Hi Simon
    I want to make the inner structures of a part visible.
    • Transparency makes the outer surfaces of the part transparent, so that parts behind it become visible.
    • Apearance makes the part so transparent that the inner edges are visible. In addition, this function is permanently assigned to the part until it is changed to 100% again.
    Hansjürg
    Try the translucent mode. It will affect the whole part studio or assembly, but you can see all the details.
    Sorry, but that is not correct.
    In translucent mode the inner edges are not visible.See the picture.
    Yes they are in translucent mode:
    Maybe "translucent" wasn't well translated to German?
