What could be causing this projection to change? (is it a bug?)
I've made very small angular adjustments to a sketch and a sketch below it that projected a curve has changed dramatically. Asking here is a really long shot, but who knows - maybe someone has encountered this before and can confirm that it's a bug, or maybe it isn't!
I'll walk through the only diffs and you'll see it doesn't make much sense:
Image 1: This is an off-axis Left/Right view illustrating the small sketch change, along with the diff between this version and the original version.
Image 2: here is the curve that is projected. This is a front/back view. I have overlaid the two curves (before and after) using the diff tool. There is a slight difference in terms of the start point and angle about the x-axis (not immediately obvious from this view) but extremely slight - 3 degrees.
Image 3: (next feature below) this is the plane that the next sketch (the one with the issue) is being drawn on. There is no diff at all between the two versions - the plane is identical in all axes.
Image 4: This is the next sketch where I project / use that helix. This is again a front/back view. Look at how far the helix is rotated about the y-axis. I have no explanation for it, since the original helix (Image 1) is not rotated in this way.
So yeah I'm baffled. I am not sure I understand how the angular change about the x-axis has turned into this dramatic angular change about the y-axis.
The only other clue is that the original sketch (from image 1) shows an equals sign with a line through it (not-equals I guess) in-between the two diffs in the list of features. Meaning, perhaps that OnShape isn't recognizing them as the same sketch? Not sure.
Thanks for any thoughts.
can you share your document?
