<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
What could be causing this projection to change? (is it a bug?)
tom_auger
tom_auger Member Posts: 134 ✭✭
I've made very small angular adjustments to a sketch and a sketch below it that projected a curve has changed dramatically. Asking here is a really long shot, but who knows - maybe someone has encountered this before and can confirm that it's a bug, or maybe it isn't!
I'll walk through the only diffs and you'll see it doesn't make much sense:
Image 1: This is an off-axis Left/Right view illustrating the small sketch change, along with the diff between this version and the original version.
Image 2: here is the curve that is projected. This is a front/back view. I have overlaid the two curves (before and after) using the diff tool. There is a slight difference in terms of the start point and angle about the x-axis (not immediately obvious from this view) but extremely slight - 3 degrees.
Image 3: (next feature below) this is the plane that the next sketch (the one with the issue) is being drawn on. There is no diff at all between the two versions - the plane is identical in all axes.
Image 4: This is the next sketch where I project / use that helix. This is again a front/back view. Look at how far the helix is rotated about the y-axis. I have no explanation for it, since the original helix (Image 1) is not rotated in this way.
So yeah I'm baffled. I am not sure I understand how the angular change about the x-axis has turned into this dramatic angular change about the y-axis.
The only other clue is that the original sketch (from image 1) shows an equals sign with a line through it (not-equals I guess) in-between the two diffs in the list of features. Meaning, perhaps that OnShape isn't recognizing them as the same sketch? Not sure.
Thanks for any thoughts.
