drawing - dimension not correct
wolfgang_maier
wolfgang_maier Member Posts: 39 ✭✭✭
Hello,
i have a door frame with hinges 497.5 mm away from the edge. When i create a drawing and show the distance of the hinge, Onshape shows 351mm. What am i doing wrong?
Link to my document:
https://cad.onshape.com/documents/c6340dbcf74fde9791d7d34e/w/5ee994347b6b0a1748d30ef6/e/26d8845e42914aec02e5d9c3
  • owen_sparks
    owen_sparks Member, Developers Posts: 2,660 PRO
    edited July 2019
    Onshape already devolving into a cult? Downvotes against rational criticism?
    Yup!
    I agree; both with your terminology / analysis of the issue above and the absurdity of down-voting such a comment.  On behalf of the community "Sorry".  For what it's worth it's not normally like that here.
  • owen_sparks
    Oh look a couple of those down-votes have gone away :)
  • victor_mendoza099
    victor_mendoza099 Member Posts: 6 ✭✭
    I’m not a pro but it is sad that dimensions on isometric views on OS are wrong. Isometric drawings are by far more compelling that any ortho view so any info associated to that kind geometric representation should not be misleading as it is on current OS drawings.
  • victor_mendoza099
    .. and OS team should not wait a democracy-style vote to fix something that is wrong.
  • erik_hjertholm
    erik_hjertholm Member Posts: 2
    I am still experiencing this in 2024! How is this not fixed yet? This is an absolute show stopper when it comes to select this as a professional cad tool. In the part studio, the selected dimension is 5000mm, while in the drawing it is 4506.94mm. Is this even on the roadmap to fix?
  • majkl_majkl457
    majkl_majkl457 Member Posts: 6
    I was just about to write about the same Onshape behaviour. This is very… sad… and bizarre "feature" of any CAD system.
  • MDesign
    MDesign Member Posts: 1,461 PRO
    How to build things has been done in 2d since the beginning.. Dimensions in 3D unfortunately isn't the norm…. yet. I do this in other software on my other projects. Definately would utilize it in OS if it was done well and makes life easy.
  • james_sedgwick
    james_sedgwick Member Posts: 2
    Confirmed still an issue, if the feature is there it should work correctly.
    Silently placing incorrect dimensions into drawings is crazy, and the length of time this has gone without a fix is negligent. It'll end up costing someone one day, if it hasn't already.
  • david_kingsbury117
    david_kingsbury117 Member Posts: 2
    Just ran into this on my first drawing - I thought I was going insane 😅
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,257 PRO
    Can Creo do this today? I stopped using it in 2021 after switching to OS. I don't believe it could then.
  • MDesign
    Interesting that I can do 3d dimensions on views like this in an architectural program like Revit but not in Onshape. Granted its a much more mature program I believe.
  • HARDWOODFP_ENGINEERING
    HARDWOODFP_ENGINEERING Member Posts: 42 PRO
    this is such a basic thing OnShape is still missing. There are posts of people complaining about this for several years ad still no fix. It`s frustrating. SolidWorks and I`d guess all other major cad systems let you add dimensions to 3d views.
