How to correct this notice: "sketch is not fully defined"?
unable to extrude on the original two dimention sketch
Unable to extrude on two D sketch. notice" sketch is not fully defined"?
You may want to start with the profile inspecter to make sure there is s closed area to extrude a solid.
Try the Onshape courses to get to grips with the basics.
Engineering textbook: https://hwh.stephenteacher.com/txtbook.html2 -
I've done several Onshape courses, including from the learning center here, and haven't run across troubleshooting that specific message ("sketch is not fully defined") anywhere. I would appreciate links to where it is discussed - because I see it all the time - and sometimes it affects what I'm doing and sometimes it seems to have no impact
@trenton_haynes631 You can design without fully defined sketches. You risk unexpected behavior after the undefined sketch if you make changes prior to the undefined sketch in the feature tree.
1 -
1
That discussion is quite helpful. Thanks!
