Perpendicular to a sloping line?
Hello
Imagine I draw a triangle and now I need to connect some lines to each side.
The lines are to be parallel and perpendicular to every side.
It is easy to draw a perpendicular line for a vertical or horizontal line,
but what is the best way to do it for a sloping line?
Should I somehow transform the triangle to make a side of it vertical
and then draw what I need for every side?
Here is a sketch that illustrates the question
https://cad.onshape.com/documents/497294dde6d7430daccb07c4/w/35ba91b8cf2c45b49165a3a1/e/fba4be4331de47d78cf99bfd
the square should be placed on the triangle's side so the bottom side of it belongs to the triangle.
Thanks!
  • alexander_potochkin
    alexander_potochkin Member Posts: 45 ✭✭
    I guess I can draw all those lines ahead of time and then connect this part to the triangle using constraints.
    This is possible but not very convenient. I'd like to make a particular line temporarily horizontal so I can easily use it as the base for the rest of the design.
  • andrew_troup
    andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
    A couple of ways I can think of:
    1) Draw a rectangle in empty space.
    - Click on "Show constraints" and delete the horizontal constraint on the bottom side.
    - Add an equal constraint between two adjacent sides to make the figure square.
    - Now click on the spacebar to make sure nothing is selected, click on an endpoint of the triangle then a corner of the square and choose "coincident".
    - Repeat this, from the word "- Now"
    2) Draw a polygon in empty space with an inscribed circle, and set the number of sides to 4.
    - Attach to the triangle, as for  rectangle 1).
    It is clear now. Thanks a lot!
