Improvements to Onshape - July 18th, 2025
2»
  • karel_works
    karel_works Posts: 22 PRO
    Great update, thanks for your awesome never ending work on this fantastic tool.
    Configuration drag and drop is gamechanger (instead of move up endless times:))
  • shawn_crocker
    shawn_crocker Posts: 1,033 PRO
    edited July 2025
    I stopped reading after this
    • The assigned default value for a configuration input is now displayed in the configurations panel
    • Configured dimensions can be renamed
    • List values can be reordered by drag-and-drop
    • Configuration inputs can be reordered by drag-and-drop 😍
    • You can expand or collapse all configuration inputs in one click
    Thanks you sooooooooo much for this! This has been a pain for me for years.
    Continuing to read, Oh my god! I'm having trouble comprehending how so many pain points for me have suddenly been solves in one update. This is awesome!
  • STEG
    STEG Posts: 140 PRO
    Update 201 is one of my favorites! 🤩👏
  • bryan_lagrange
    bryan_lagrange Posts: 1,036 ✭✭✭✭✭
    @Alex_Pitt I am experiencing the same thing. All my defaults are in inches. When I create a .dxf it defaults to meter. I change to inch it to inch but if I close the program it goes back to meter.
    Is there a default setting for .dxf export that can be set?
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • Alex_Pitt
    Alex_Pitt Posts: 77 PRO
    edited July 2025
    @bryan_lagrange Don't think so. If you're talking about drawings (rather than exporting from a part studio) I think it defaults to the units specified in the drawing, but I don't know how to change those. They may be locked into the DWT file of your drawing border. Before export, when you change the settings away from "Use drawing units", it does seem to remember the change for subsequent drawings in the same Onshape document. So you should only need to do it once per OS doc.
    My apologies. Onshape doesn't remember the export settings for particular drawings between sessions. Today, the export options were back to the default: "Use drawing units."
    But yes, it could be useful to set defaults for this in your company settings or user account preferences.
  • josh_grasby942
    josh_grasby942 Posts: 3
    Wow, this is a big one! Full spectrum of improvements both new and formerly requested. Great work everybody
  • adrian_vlzkz
    adrian_vlzkz Posts: 309 PRO
    Can we allow for all Dimensions to be edited/renamed, not just configured ones.
    CAD Engineering Manager
  • bryan_lagrange
    +1 to what @Jaro_Lansink posted.
    Bryan Lagrange
  • Conant_Custom
    Conant_Custom Posts: 10 PRO
    I do not see Straight Pipe Tap as an option in the hole tool. The "Straight Tap" option seems to revert all settings to UNF thread styles. As a lighting manufacturer, 1/8 NPS is one of our most commonly needed threads.
  • Jacob_Marble
    Jacob_Marble Posts: 2
    The tapered pipe threads will be very handy for me. But, it looks like it is not yet supported for external threads. So we're only halfway there.
  • test_user242
    test_user242 Posts: 10
    I can't find the metric straight pipe tap option for a part I've designed - do I have to create a new part or something in order to be able to access it?
  • Tinus
    Tinus Posts: 6 PRO
    Pipe threads! Yes!
  • Axel_Kollmenter
    Axel_Kollmenter Posts: 437 PRO
    YAAAAAHAHHAHA FINALLY DRAG AND DROP MOVEMENTS FOR CONFIGS… OMG I´VE BEEN WAITING FOR THIS ALL MY LIFE!"!!!!! Bye Bye right click- up - right click - up - …
    yes yes everything else is cool too but finally i have more free time in my life again because i no longer have to make 4 million clicks on hundreds of configs.
    Best regards,
    Axel Kollmenter
  • ry_gb
    ry_gb Posts: 265 PRO
    Love being able to export from structured view. Can we add the ability to export multiple parts/drawings/etc. from this view as well? That would speed things up so much, especially since I have some of these parts scattered across different releases.
    Ramon Yip | glassboard.com
  • Larkin
    Larkin Posts: 15 ✭✭
    I literally said "finally!" on every dot point in the configurations updates. TYSM
  • kev_keeg
    kev_keeg Posts: 9 ✭✭
    Don't really know where this belongs - forgive if wrong place.
    Suggestion: there should be a button which when pressed shows ALL functions UNDER ALL BUTTONS.
    I'm not newbee - but i find myself spending lots of time trying to find a function i know exists - but don't know where!
    thanks
  • fred_burtt
    fred_burtt Posts: 20 PRO
    DXF export units now default to workspace units. SOLVED!
    Thanks, guys!
  • bryan_lagrange
    @fred_burtt I would check to make sure that it is not a document you have changed the default before. I just opened Onshape and made a new document to check and it still wants to export out meter even though my defaults are se to imperial.
    Bryan Lagrange
  • fred_burtt
    I did create a new doc this morning, and it used the workspace default (inches).
    Just tried it again and it's back to meters. Spoke too soon!
  • EricMartin
    EricMartin Posts: 3 PRO
    We also need the dxf export to be fixed, or just put it back to the way it was.
  • We also want the DXF export to be changed to default to the document setting. It is fine being able to override it but having to actively set the scaling of every export is unnecessary extra time and sources of error added. I just came back to work after the summer and this was the first thing my boss asked me to fix because they have had trouble with it for weeks now.
