New featureScript: Voronoi face lattice
wille_j
wille_j Member Posts: 108 ✭✭✭
Hi everyone,
This is my first post here, so let me start by introducing myself. I’ve been a professional Onshape user since 2019 and have been creating FeatureScripts from the very beginning. My background is in aerospace engineering, composite material science, and robotics. In my day job, I’ve had the privilege of working on some truly exciting engineering projects, but up until now my FeatureScripts have always lived strictly inside our Onshape Enterprise environment. That said, I’ve long wanted to share some of my work with the wider community. So, during my summer holiday, I finally took the chance to build something for fun for myself, but also for all of you! I hope you’ll find it useful.
The only required input for the FeatureScript is a flat face or sketch surface, everything else is optional. On that face, it creates a Voronoi lattice, an organic-looking structure you’ll recognize from patterns in nature, biology, physics, architecture, and even consumer product design.
I’ve also implemented a random pattern generator, adapted from Philip Thomas’s Random Surface Perturbator, based on earlier work by Maximilian Schommer and Ilya Baran.
To demonstrate usage, I’ve included examples showing how the flat-face limitation can be worked around using wrap features, though I’m sure the community will find other creative ways to apply it. A version that works directly on more complex surfaces may come later. Screenshot 2025-08-18 at 20.45.44.png
Key Features
  • User-selected or pseudo-random Voronoi points (with seed input)
  • Choice between bezier-curve or polyline cells
  • Option to truncate circular concave/convex edges for cleaner bezier outputs
  • Cell offset control for wall thickness
  • Short-edge filtering to avoid overly sharp bezier artifacts
  • Option to output only 2D geometry (useful for wraps or other downstream features)
  • Blind extrude with boolean and composite part options
Known Limitations / Future improvements
  • Currently works only on flat faces and sketch surfaces, option for general surface would be nice
  • Polyline output limited to 2D surfaces (sketch option disabled for now)
  • Extrude is blind-only (future: up-to, two-sided, etc.)
  • Editing logic function addition to pre-select the extrude direction upon creation would be nice.
  • Truncation could be extended to non-circular curves
  • Short-edge filter can misbehave if set too high
  • Large offsets may break the feature (error handling would help)
See it here: Voronoi face lattice.
If you discover any bugs, have ideas for improvements, or would like to collaborate, please reach out. If you like the tool, I’d love for you to use it, share it, and even improve upon it, just please give credit and share your work under the same license (CC BY-SA).
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,076 PRO
    You certainly took your implementation a lot further than I did. Mine also isn't random seeded voronoi but the deterministic version based on the delaunay mapping of a given face. I'll have to set aside time to polish mine up and make it a real feature instead of just a thought experiment at some point. The one thing I might suggest adding to your implementation is a caching function by shoving some of the heavier calculation work into an editing logic step. My implementation has a lot of edge flipping operations that start to build up regen time the more I have but once the map is made the actual drawing steps are super snappy, so I did some reworking to make it build the geometry maps while the user is editing the feature but not during normal rebuild.
  • wille_j
    I was looking at your script, super impressive! I've been meaning to have a look into that caching trick, it seems incredibly powerful. I think your explanation here means I have a better chance to grasp the concept. Thanks for explaining the principles!
  • EvanReese
    EvanReese Member, Mentor Posts: 3,030 PRO
    @wille_j Thanks for sharing this! I've been interested in writing one for a while, but never got around to it! Very nice feature.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,938 PRO
    Cool! Nice to meet you. 😎 And ty for sharing!
    RENDERCAD
  • wille_j
    Thank you @EvanReese and @MichaelPascoe
  • andy_colborn
    andy_colborn Member Posts: 13 PRO
    @wille_j this looks awesome! I literally checked just over a month ago if anyone had built a voronoi FS yet and couldn't find anything.
    I've been trying a bit myself but have only got so far as hacking @EvanReese's attractor pattern to try and add a Poisson Disk sampling option. The idea was to first figure out how to add evenly spaced seed points in UV space, then maybe use them for making voronoi cells? IDK
    So far mine still looks like this since the points are added iteratively around an initial seed / annulus. The method you're using, which looks like it jitters a grid to add some randomness seems way better at filling the surface.
    Anyway, thanks for the awesome work! I'm definitely going to play around with this.
  • EvanReese
    @andy_colborn It's an honor to be hacked, sir 🫡 I've daydreamed about doing a Poission Disk version, but ended up moving on to other things. Let me know if you figure it out!
  • wille_j
    @andy_colborn thanks for the kind words! Thank you for your patience with my delayed response.
    I had a look at the algorithm and it's a similar style random-point generation so I believe you're on the right path. I would recommend you to have a look at the Random Surface Perturbator. I've worked off those functions in my script. It seems it does much of the same thing as Poisson Disk but not the check for too close point distance.
    It's an intriguing extension of the Voronoi script to use Poisson Disk sampling to get a more natural look of the Voronoi, thanks for the tip!
